Activity Forums Apple Final Cut Pro Legacy HD deck setup from FCP
  • HD deck setup from FCP
    Posted by John Knapich on November 9, 2009 at 2:46 pm
    We run OS 10.5.8 on an Intel Quad Core. When outputting to tape from FCP we usually come out of our Kona KHe card using the SDI and remote cable. We have not used a black generator in the past. I usually black a tape with the appropriate TC and then lay down my bars/slate/program by inserting. THis usually works fine. We have done this mostly with Digi Beta or DVC50. I should add we own only the DVC50 and usually rent a DigiBeta or HD deck when necessary.
    i am anticipating going to Panasonic DVCPRO HD in the near future.
    For those of you who do not have a large control room with a rack of decks, do you also use a black generator to sync up your deck and system?
    I am interested in other editors setups since we want to improve on this.
    John Fishback
    replied 16 years, 10 months ago
    3 Members · 4 Replies
  • Shane Ross
    November 9, 2009 at 3:02 pm
    [John Knapich] “For those of you who do not have a large control room with a rack of decks, do you also use a black generator to sync up your deck and system?”
    Yup. I output to HDCAM SR, so we have the AJA Tri-sync generator. Also have BetaSP, and use SYNC with that too. Always have.
    Shane
  • John Knapich
    November 9, 2009 at 3:18 pm
    So you hookup the Ref-In cable from the Kona card and the deck ref to the AJA tri-sync and that locks it all up.
    Dont know why, but I never truly understood the sync business.
  • Shane Ross
    November 9, 2009 at 6:45 pm
    Sync is basically a PACEMAKER for things. It makes sure that the capture card and the deck are in sync…they have EXACTLY the same Hz rate and frame rate. I don’t know the DEEP engineering behind it, just that it is needed.
    And yes, you send ref to the card and to the deck.
    Shane
  • John Fishback
    November 10, 2009 at 5:03 pm
    Checkout the AJA Gen10. It’s a great sync gen and does both SD (black or bars) and HD tri-sync simultaneously (if desired). It’s very flexible.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
