Activity › Forums › Apple Final Cut Pro Legacy › HD Data/Storage Chart
Joe Huggins
January 27, 2009 at 8:57 pmthanks. you did see the second post with the file / chart uploaded right? Joe
Thanks, Film Joe
Jeremy Garchow
January 27, 2009 at 9:28 pmJoe, thanks for posting this.
What more do you need on there? That’s pretty comprehensive. The only thing that really missing are different 720pN frame rates, and…well…PAL. Remember that ProRes is the equivalent of DNxHD 145 and ProResHQ is the equivalent of DNxHD 220. I still think the free AJA Calculator is much more versatile and it can also calculate times with different numbers of channels of audio (0-16). It does not have the avid low res solutions on there, however.
Jeremy
Joe Huggins
January 27, 2009 at 9:55 pmI’ll check the AJA calculator, but I wanted on with ProRes in SD and HD variations, and the new Red format info. I thought this chart came from some HD reference site or Cow data that may have been easy to find online.
Thanks, Film Joe
Jeremy Garchow
January 27, 2009 at 10:12 pm[Joe Huggins] “and the new Red format info. “
Well, since you won’t be editing native 4K it’s all about what you would transcode to, that most likely being ProRes or HQ at 1920×1080 and 23.976 fps (or 30, whatever you’re shooting). Perhaps 2K. Red Raw, I believe, is up just above 25MB/sec at 444, 4k, 24p, which is a data rate right aorund then Uncompressed 10 bit SD, but the frame size and information is so complex, rt playback of 4K material is reserved for the higest end systems.
For ProRes and (HQ) in HD, you can use the DNxHD 220 and 145 as guides, but it’s a VBR codec so those numbers are just targets. In reality, ProRes will probably be a bit smaller than 145 or 220 mbps.
Not sure about ProRes SD sizes. I’d have to look those up.
Jeremy
Elijah Lynn
February 2, 2009 at 11:29 pmI just came across this site from Shane Ross’s blog and I thought it was relevant to the thread.
https://www.moviola.com/fcs_video_storage
David Poole
September 27, 2009 at 5:55 amThe original chart can be found here: https://www.asiamediaproducts.com/Facilis%20Config%20Guide%200505.pdf
Joe Huggins
September 28, 2009 at 3:43 pmDavid,
Wow, that’s a great response to an old post. You found it! I guess they have not updated that to current files like ProRes, but that is the exact page. Thanks again.
Thanks, Film Joe
