Activity Forums Apple Final Cut Pro Legacy HD compression for web
  • HD compression for web
    Posted by Eamonspro on July 17, 2007 at 1:12 pm
    Hello,
    I have a question for any professionals out there that know how to compress HD video for web. I’m trying to get quality standards that reach this level for web. Can anyone point me to a good website and/or formula to use and what codecs that should be used. I would be doing software compression through Final Cut Pro or compressor.\
    Here is a sample of the quality I’m trying to achieve.
    https://www.helinet.com/54.129.0.0.1.0.phtml
    Thanks to all for any assistance you can provide.
    Eamonspro replied 19 years, 2 months ago 4 Members · 7 Replies
  • 7 Replies
  • Shane Ross
    July 17, 2007 at 3:44 pm
    HD compression for web distribution? The only option then is H.264. There are many export options for that format in Compressor. Under the QT 7 streaming and download options.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Chris Borjis
    July 17, 2007 at 4:08 pm
    Lots of studios (mine included) distribute HD dailies as Windows Media 9 files.
    here are some basic specs:
    1280×720 (all are done this way to keep size+interlacing issues down)
    Video: Bitrate VBR, framerate 29.97, average bitrate 4mbps
    Audio: VBR Quality 25, 44khz 2 channel
    This would require an investment in flip4mac pro.
    I’ve had lots of clients not been able to playback H.264 quicktimes or quicktimes at all, so thats what I do.
  • Eamonspro
    July 17, 2007 at 4:13 pm
    Thanks for the input guys. I’m looking for more specifics on readying hd video for web streaming so clients would be able to look at it over a website or ftp.
    Basically I’m trying to achieve the same quality that the below video from helinet has on their website and to maximize quality while keeping file sizes small.
    Is there a formula that one could point me to for figuring out the data rates and keyframes to maximize this quality?
    Thanks again, I hope I’m a little clearer this time!
  • Eamonspro
    July 17, 2007 at 4:25 pm
    [eamonspro] “Basically I’m trying to achieve the same quality that the below video from helinet has on their website and to maximize quality while keeping file sizes small.”
    Sorry forgot to link the video I was talking about.
  • Chris Borjis
    July 17, 2007 at 5:40 pm
    [eamonspro] “Is there a formula that one could point me to for figuring out the data rates and keyframes to maximize this quality”
    keyframe formulas that maximize efficiency:
    150 for 15fps video
    300 for 30fps video
    the data rate is 4mbps as I said.
  • Jeremy Doyle
    July 17, 2007 at 6:38 pm
    I just downloaded the video you were using as an example and pulled up the get info in quicktime and here is that video’s specs
    H.264
    720×405
    Millions
    AAC stereo 48k
    FPS -29.97
    data size – 23.49 megs for 2:21 TRT
    data rate – 1389.38 kbits/s
    This might give you a starting point.
    Good luck
  • Eamonspro
    July 18, 2007 at 8:33 pm
    Thanks Borjis and Jeremy for all the help! I tried both last night and both looked great. I now can also offer up both formats for my clients! You guys are lifesavers!
