HD Component Playback Squished
I am using a Kona LH in FCP 6.0.4 and running the component output to an HDTV for monitoring. The sequences and Capture presets are “AJA Kona LH: 1080psf 23.98 Apple ProRes HQ” The signal comes in perfect except the image is squished. The 1920×1080 16:9 image is displayed as a 4:3 image squished to the right of the frame. Based on the clarity of the image displayed I can tell the the pixels are present simply being displayed as 4:3 instead of 16:9. Since it is an HDTV there is no 16×9 button, is there a way to force AJA to output 16×9?
Also worth noting – when I have AJA’s Control panel program output bars to the HDTV it does the same 4:3 squishing present in FCP so I know this is not an issue with FCP.
Thanks in advance for the help!
