Activity › Forums › Panasonic Cameras › HD component cable
HD component cable
Posted by Lars Wikstrom on April 25, 2007 at 4:43 amWhere can I buy an extra HD component cable for the HVX?
-Lars
Jeremy Garchow replied 19 years, 4 months ago 5 Members · 8 Replies -
Jeremy Garchow
April 25, 2007 at 5:21 pmand is there one available that has BNC connections instead of RCA?
Peter Mackay
April 26, 2007 at 1:12 amNo, you have to have them made. I have two now, one that is the original length with BNC on the end, and another that is just 12″ long with BNC. I use that one the most to connect the onboard Marshall monitor. One of the big problems I had with the long cable was just the weight of it hanging off the monitor, that would eventually cause a break in the cable just behind one of the BNC connectors.
Lars Wikstrom
April 26, 2007 at 3:03 amYes I was lookign for a smaller one as well. I just bought a Marshall monitor and am looking for a smaller one and also as a backup just in case. Did you make it yourself or did some one else do it?
-Lars
Barry Green
April 26, 2007 at 4:15 pmFYI, the HVX’s cable is compatible with the one that’s used by the Canon XHA1 and XHG1 and XLH1 and the JVC HD1 and HD10, so if you find the kind of cable you want being offered for any of those then you can also use it on your HVX.
Get the most from your DVX camera. The DVX Book and DVX DVD are now available on ebay and at Amazon (https://www.fiftv.com/db) -
Lars Wikstrom
April 26, 2007 at 5:53 pmohhh… I thought it was HVX only. Thanks for that info.
-Lars
Peter Mackay
April 26, 2007 at 9:12 pmI used the cable that came with the camera and had the BNC’s crimped onto it at Studio Exchange here in LA. The smaller cable was constructed of a full length one that we cut down and added the BNC’s that was also done at Studio Exchange. I would have done it myself but I don’t have the crimpers for that size of cable. The full length cable came from B&H in New York about $40 if I remember correctly, and as Barry stated it was a canon cable.
Arthur Luhn
April 26, 2007 at 11:31 pmWhat is wrong with HD component to RCA? I have a RCA to BNC to my monitor and it looks fine. I see plenty of HD to RCA on bhphotovideo… but no HD to BNC..
Is RCA inferior?
Thanks..
Jeremy Garchow
April 26, 2007 at 11:45 pmNot at all. My monitor is BNC and the adaptors constantly pop out. BNC is made to not come apart unless you are really trying. As far as signal quality, there’s no discernible difference.
Jeremy
