Activity › Forums › Adobe After Effects › HD comp size question
  • HD comp size question
    Posted by Dave Hirschberg on October 16, 2006 at 1:18 pm
    I need to do some 16X9 graphics and I am not sure what size to set the comp size to. The final output is NTSC DVD on a 16X9 HD TV. The tv pixel ratio is 1366 X 768 so do I create the comp size to match or select another size? Please help this is urgent.
    Dave
    Dave Hirschberg | Motion Graphics Designer | Creative Department
    TELEMUNDO/NBC NY | 201.969.4204 | dave0@lowerthird.com | david.hirschberg@nbcuni.com
    Steve Roberts replied 19 years, 11 months ago 3 Members · 3 Replies
  • Andrew Kramer
    October 16, 2006 at 1:21 pm
    I would use the widescreen preset for NTSC. If you’re going to DVD then it’s the only way. It’s 720×480 with a Pixel Aspect Ratio of 1.2
    Cheer,
    Aner
  • Dave Hirschberg
    October 16, 2006 at 2:09 pm
    Thanks. Another question. Should I set up the comp at a higher comp size like 864 X 486 and then pre compose down or just work in the D1 Widescreen exclusively?
  • Steve Roberts
    October 16, 2006 at 5:09 pm
    [Dave LaRonde] “Otherwise, 720×486 Widescreen is okay”
    You mean 720×480 widescreen, yes? 🙂 Although compressors will take 486, I seem to recall a bit of softness with 486 with some.
