Activity Forums Apple Final Cut Pro Legacy HD combined with SD
  • HD combined with SD
    Posted by Jeffrey Weiser on May 12, 2008 at 2:20 pm
    I am having trouble combining 2 types of media on an SD timeline. I am bringing an HD Quicktime spot (codec: Apple ProIO vout 2vvy imdc integer Big Endain timecode) into an SD timeline with existing spots on it. The timeline was set up as uncompressed 8 bit 4:2:2. When I bring in the HD Quicktime spot and render it I get bad looking video and jagged edges on the graphics. Also, when I export for burning onto DVD, the shots are squeezed. Amy suggestions? Thanks.
    Jeff Weiser
    Director/Cinematographer
    TDN Artists
    jeffweiser@earthlink.net
    Ron Kennard replied 18 years ago 5 Members · 8 Replies
  • 8 Replies
  • Shane Ross
    May 12, 2008 at 3:24 pm
    [jeff weiser] “I am bringing an HD Quicktime spot (codec: Apple ProIO vout 2vvy imdc integer Big Endain timecode)”
    Well, where are you getting that? I have never heard of that format before.
    Shane
    GETTING ORGANIZED WITH FINAL CUT PRO DVD now for sale!
    http://www.LFHD.net
    Read my blog!
  • Jeremy Garchow
    May 12, 2008 at 4:11 pm
    is your HD spot progressive or interlaced? Is your SD timeline progressive or interlaced?
  • Jeffrey Weiser
    May 12, 2008 at 4:37 pm
    I did command i to get information about the clip.
    Jeff Weiser
    TDN Artists
  • Jeffrey Weiser
    May 12, 2008 at 5:30 pm
    It is 1080 24p and SD 8bit interlaced. Does this present a problem?
    Jeff Weiser
    TDN Artists
  • Kevin Monahan
    May 12, 2008 at 5:39 pm
    How are you monitoring picture? How does it look when your Canvas is at 100%?
    Kevin Monahan
    http://www.fcpworld.com
    Author – Motion Graphics and Effects in Final Cut Pro
  • Shane Ross
    May 12, 2008 at 5:43 pm
    Where did this clip come from? Getting Info tells very little. I have never heard of that codec.
    Mixing Progressive and Interlaced can be tricky…depends on what your sequence settings are. What are the main sequence settings? What is the main footage and what are you adding to that? Meaning, is the sequence HD and you are adding SD, or is it SD and you are adding HD?
    Shane
    http://www.LFHD.net
    Read my blog!
  • Jeremy Garchow
    [Jeff Weiser] “Does this present a problem?”
    Yes as you are trying to mix frame rates. You need to add pulldown to your HD spot in After Effects or with a plug in like Fields Kit.
    Jeremy
  • Ron Kennard
    August 29, 2008 at 9:31 pm
    Hey jeff
    Ron Kennard-looking for website for Ft Wayne hospital shoot–your directors cut.
