Activity Forums Adobe After Effects HD capture wierdness and AE renders
  • HD capture wierdness and AE renders
    Posted by Deleted User on May 7, 2009 at 2:20 pm
    I’m using a NLE from Harris (formerly Leitch) called VelocityHD. Great editor, just not highly adopted. I’ve been using AE for the last 2 years and various other composting programs for at least 10 yrs but always with SD footage. Recently I have started capturing 1080i 59.94 uncompressed 10bit footage with my NLE. After I assemble my timeline I render the sequence to AE for various treatments. The NLE renders the sequence at what it indicates as 29.97 fps so in AE I interpret the footage as 29.97fps upper field first. If I then render the resulting comp at 29.97 and import it back into the NLE the clip plays back at frames only with movement not being smooth. If I render the comp out at 59.94 the imported clip plays back smooth in the NLE but is twice as long as it should be and I have to apply a 200% speed adjust to compensate. If I interpret the footage in AE as 59.94, the 30sec clip shows up as 15sec on the AE timeline.
    Any ideas as to how I can get an exact length render out of AE?
    Lee
    CTV Calgary
    Deleted User replied 17 years, 4 months ago 2 Members · 3 Replies
  • Deleted User
    May 7, 2009 at 4:27 pm
    Thanks Dave for your input. I will try to look for other VelocityHD users that are more familiar my hardware/software combo.
  • Kyle Hamrick
    May 7, 2009 at 6:22 pm
    Lee,
    It’s been awhile since I used Velocity myself (and it was SD) but just an off-hand thought….
    Any updates to the .dps driver for AE or anything of that nature?
    Kyle Hamrick
    Editor/Motion Graphics Artist
    http://www.kylehamrick.com
  • Deleted User
    May 8, 2009 at 6:50 pm
    I think I figured it out. I precomped the 59.94 timeline into a 29.97 timeline for final output from AE. The resulting import in my NLE works well.
    Lee
    CTV Calgary
