Activity Forums Apple Final Cut Pro Legacy HD CAPTURE preset
  • HD CAPTURE preset
    Posted by Alex on April 13, 2006 at 11:43 pm
    when i choose ‘Blackmagic HDTV 1080 25Hz – 10 bit’ as my capture preset (for 25p footage), the summary says:
    Using Blackmagic HDTV 1080 for video input
    Blackmagic HDTV 1080i 25Hz – 10 Bit using NTSC
    25 frames per second
    Blackmagic 10 Bit at Best quality.
    24 bits per pixel
    1920 by 1080
    where does the NTSC come from? all the settings are for 25 fps.
    i did a test on the captured footage, and it plays fine on a 25fps timeline, and its format reads 25fps. i dont understand how the ‘NTSC’ is relevent here? or why it is the only option in the 10bit settings?
    any ideas?
    (using power Mac G5 / FCP4.5 / Decklink HD Pro / Sony HD CAM deck / SONY HD CAM 40min tapes)
    Walter Biscardi replied 20 years, 5 months ago 3 Members · 4 Replies
  • Walter Biscardi
    April 14, 2006 at 12:07 am
    [alex] “i dont understand how the ‘NTSC’ is relevent here? or why it is the only option in the 10bit settings?
    any ideas?”
    What did they say in the BlackMagic forum?
    Walter Biscardi, Jr.
    Director, “The Rough Cut”
    https://www.theroughcutmovie.com
    Now Posting “Good Eats” in HD for the Food Network
  • Alex
    April 14, 2006 at 3:41 am
    didnt get a response
  • David Roth weiss
    April 14, 2006 at 4:42 am
    Let your eyes be the judge. If it palys back fine on your PAL monitor then it must be PAL.
  • Walter Biscardi
    April 14, 2006 at 10:46 am
    [alex] “didnt get a response”
    well does it work correctly? If it does, then don’t worry about it. Presets are mislabled all the time and it doesn’t matter as long as it works correctly.
