Activity › Forums › AJA Video Systems › HD capture from D5 – Video goes below 7.5IRE
  • HD capture from D5 – Video goes below 7.5IRE
    Posted by Michael Garber on April 21, 2006 at 3:42 pm
    Hi All,
    I’m using FCP to color correct some footage captured from D5 1080i 59.94. The Kona2 SDI Downconvert out is feeding an Io which is then feeding a waveform monitor. I know, a little janky, but it works.
    Here’s what I’m noticing. The blacks go below 7.5IRE on the waveform monitor. In the past, when I’ve captured HD-CAM 10-bit before – and also when I’ve edited/cc’d DVCPRO-100 or HDV, this hasn’t been a problem.
    I’ve checked all my downcovert settings – everything’s set to 7.5 IRE and BETA US. Also checked the analog output of the D5 deck to the waveform monitor and the blacks go even lower – below 0.
    Also, the sequence is set to 10-bit rendering, not RGB.
    Michael
    Walter Biscardi replied 20 years, 5 months ago 3 Members · 3 Replies
  • Gary Adcock
    April 21, 2006 at 5:32 pm
    [Michael Garber] “I’m using FCP to color correct some footage captured from D5 1080i 59.94. “
    HD is not 7.5 but 0 IRE.
    only analog SD should be at 7.5 IRE, Digital video should be at 0
    gary
    Join us at the NAB FCPUG SUPERMEET
    Wed April 26th @ the RIO for details go to https://www.lafcpug.org/nab_2006.html
  • Michael Garber
    April 21, 2006 at 6:37 pm
    Gary –
    The weird thing is that the footage shows 0 blacks only in 10-bit. As soon as I move the footage to an 8-bit sequence, blacks rest at 7.5.
    This is true even if I monitor the composite out of the d5 deck and the deck is set to composite out at 7.5.
  • Walter Biscardi
    April 22, 2006 at 1:51 pm
    [Michael Garber] “The Kona2 SDI Downconvert out is feeding an Io which is then feeding a waveform monitor. I know, a little janky, but it works.
    Here’s what I’m noticing. The blacks go below 7.5IRE on the waveform monitor.”
    You should never monitor your HD in SD when CC’ing HD. When you do this, you don’t push the colors as much as you should because colors start to look over saturated very quickly in SD but are fine in HD.
    HD can go into super black, that is -0 IRE. I’ve had camera footage in DVCPro HD go to -7 on the blacks.
    7.5 setup is only for SD NTSC analog. In HD you’re only limited by what the networks set, which is usually 0.
    Walter Biscardi, Jr.
    Director, “The Rough Cut”
    https://www.theroughcutmovie.com
    Now Posting “Good Eats” in HD for the Food Network
