Activity Forums AJA Video Systems HD Cam TC Mystery
  • HD Cam TC Mystery
    Posted by Brian Schildhorn on November 3, 2010 at 8:09 pm
    So, got a dilemma,
    Printing to HD Cam, blacked the first two minutes,(00:58:00:00-01:00:00:00)
    Now trying to have FCP through a Kona LHi stripe the rest of the tc while I lay video and audio tracks along with it. (this is just so I don’t have to black the whole tape before laying off)
    Laying down video and audio fine, just a problem where the time code inserts.
    As soon as it inserts, it gives me an offset number, just something random (from the blacks 58:49:29 to 01:90:20:00 some strange number and continues on from there)
    I have tried trouble shooting the problem, It’s gotta be one of three things. FCP, Kona LHi, or the VTR itself.
    I don’t think its FCP, the timecode on the sequence is how I want it and inserting via the edit to tape should provide me that TC (with the TC button clicked of course)
    Kona’s software has little under the TC tab and I have the output checkmarked as “Use Quicktime Timecode” with NO timecode offset.
    last but not least, I have the deck (an hdcam F500) TC Menu on the following:
    TCR Select – LTC
    TCG Mode – PRST (with TCG Source – In LTC)
    Run Mode – Rec
    Non Drop (as is my sequence)
    and lastly VITC – TCG
    Everything is going HDSDI from the kona to the VTR.
    I read on the manual that the TC menu on the hdcam deck might need to be altered to select the HDSDI port as the main source of TC, But when I tried what I thought was the correct input, still nothing!
    Could really use some help on this one
    Mac Pro 2×2.93 GHz Quad-Core Xeon
    8GB 1066 MHz DDR3
    Kona LHi
    HDCAM F500
    ________________________________________________
    I think every age has a medium that talks to it more eloquently
    than the others. In the 19th century it was symphonic music and the
    novel. For various technical and artistic reasons, film became that
    eloquent medium for the 20th century.
    -Walter Murch
    Brian Schildhorn replied 15 years, 10 months ago 2 Members · 2 Replies
  • Dave Po
    November 3, 2010 at 9:51 pm
    Have you set the internal timecode preset on the VTR? Every time you record on the VTR it advanced the internal TC, if you rewind and record again it will start where you left off. You need to reset this to match your inpoint. Email me if you have anymore questions: dave@desmoinesfreelancer.com
  • Brian Schildhorn
    November 3, 2010 at 10:17 pm
    Hey, just tried email you,
    So are you saying that it’s still using the internal timecode generator instead of the timecode being sent along the HDSDI cable?
    If this is the case, how is it that just laying black to tape gives me exact timecode from fcp?
    -Walter Murch
