hd burning
Posted by Trey Isbell on July 31, 2008 at 8:37 pmdo you have to have a high definition dvd burner to burn hd dvds or can you burn hd on a regular dvd burner.
John Rofrano replied 18 years, 1 month ago 2 Members · 5 Replies -
John Rofrano
July 31, 2008 at 9:27 pmWell, if you really mean HD DVD and not Blu-ray then there are no HD DVD burners and they will never exist. HD DVD lost the high def war before any burners were commercially available. (there was a very small amount shipped as part of OEM systems but you couldn’t just buy one)
You can make HD DVD or Blu-ray discs on standard DVD’s but your time is limited to about 15-20 minutes since DVD’s don’t have enough room for the high bit-rates of HD. There is no reason to make HD DVD discs so I would concentrate on making Blu-ray compatible DVD if that’s what you are looking to do.
Vegas Pro 8.0 can do this directly from the timeline using Tools | Burn Disc | Blu-ray Disc…
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Trey Isbell
August 1, 2008 at 4:54 pmso when you are burning blu ray you are supposed to burn directly from timeline and not use dvd architect
John Rofrano
August 1, 2008 at 6:51 pmIf you have DVD Architect 5 you can certainly use that to burn a Blu-ray disc format to a regular DVD.
~jr
Trey Isbell
August 1, 2008 at 9:43 pmSo what do you render out to (mpeg2) or is there another format to render bluray to use in dvd architect.
John Rofrano
August 1, 2008 at 11:13 pmBlue-ray supports MPEG2 or AVC. Vegas Pro 8.0 has a collection of templates that all start with “Blu-ray” in the name. You’ll find them under the MainConcept MPEG-2 and Sony AVC types. Just render to one of those. Because I shoot HDV 1080i on my Sony Z1, I stick with the MPEG-2 1080-60i templates but use the template that suits your HD footage.
~jr
