Activity › Forums › Adobe Encore DVD › HD build process
  • HD build process
    Posted by Jeremy Wiles on August 20, 2007 at 6:35 pm
    I’ve done some searching on the issue, but have run into some dead ends.
    I’ve exported my project from Premier 1.5 through Adobe Media encoder as NTSC 16×9 widescreen Progressive, high quality, 7mb per second preset. I import the m2v video and audio file that was created into encore. Does encore automatically recognize the m2v audio file and attach it to the video file?
    Also, I have a first play feature that I created in an HD format from After effects. Should I convert this to 720×480, or will encore allow me to import a 1280×720 video and reconvert to 720×480?
    Final question: My menu, which I created in After effects and rendered as a quicktime, is 1280×720. Should I convert this to 720×480 for encore? My concern is that everything should match the m2v file that I imported from premier.
    Yeah, I think I’m making myself confused with this whole process.
    I’m not as confused as you am I think. lol.
    Jeremy
    Jeremy Wiles replied 19 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
