Activity Forums Adobe After Effects HD broadcast design
  • HD broadcast design
    Posted by Ocube.tv on August 23, 2007 at 6:11 pm
    Hi everyone
    I want evaluate how to charge in a HD broadcast design project; like an opening and packaging TV show
    a 5000$ project in SD fomat, how to charge for HD 1920×1080
    After effects and Macpro workstation
    no output on tape considering
    thanks
    jf
    http://www.ocube.tv
    Del Holford replied 19 years, 1 month ago 2 Members · 1 Reply
  • Del Holford
    August 27, 2007 at 2:31 pm
    I’m fortunate to not have to deal with billing but I’ve worked with local animators/motion graphics artists on the recieving end of HD projects.
    Since the files sizes will be 6 Mb per frame instead or 1 Mb, consider the amount of time it will take to render your projects. It isn’t linear – more likely about 3 times longer.
    The output can be tif or targa sequences or Quicktime movies. That too will take a bit longer but delivering files is much more convenient than videotape. If you factor that into your project quote you should be in the ballpark.
    Hopefully other COW sages may wish add to this post to give you an enlightened answer. Good luck.
    Del
    fire*, smoke*, photoshopCS3
    Charlotte Public Television
