Activity Forums Apple Final Cut Pro Legacy HD and SD sequence output
  • HD and SD sequence output
    Posted by Caton Clark on December 10, 2007 at 4:09 pm
    I need to output a project that has both SD and HD footage (DV/DVCPRO + DVCPRO HD) in the same sequence.
    I’m running 5.1.4 and I’m wondering if need to do any kind of conforming of the media before output.
    Any help would be great.
    Thanks.
    Russell Lasson replied 18 years, 8 months ago 2 Members · 3 Replies
  • Russell Lasson
    December 10, 2007 at 6:50 pm
    What’s your frame rate and what codec is the project currently?
    -RUss
  • Caton Clark
    December 10, 2007 at 7:19 pm
    Frame rate is 29.97 and codecs are mixed between DV/DVCPRO + DVCPRO HD
  • Russell Lasson
    December 10, 2007 at 9:25 pm
    For your DVCPROHD export, I would just use the File-Export-QuickTime Movie command with current settings.
    While you could also use the same command to export your DV master by changing the current settings to DV NTSC, I prefer using compressor for it. You’ll also need to decide if you DV version will be letterbox or anamorphic (compressor will support both).
    -Russ
