Activity › Forums › Avid Media Composer › HD and SD footage
HD and SD footage
Posted by Timothy Lydon on June 23, 2014 at 3:52 pmHello everyone!
I just began going through the footage I have for a short video I am editing. I have SD (640×480) and HD footage. I have never worked with this before, could someone provide some guidance on how to begin?
Thank you!
Timothy
Timothy Lydon replied 12 years, 1 month ago 4 Members · 6 Replies -
Shane Ross
June 23, 2014 at 5:15 pmCreate an SD project, AMA and transcode the SD footage in there. Then make a master HD project, and drag the bins over on the finder level…and import the HD footage into the HD bin.
Unless you want to use external conversion options to upconvert the SD footage first…
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Nick Griffin
June 23, 2014 at 5:39 pmObviously not for everyone, but I’ve been very happy with playing out of an SD workstation using a Kona LX box using SDI into our HD station with the Kona III doing the up-converting. Would this hardware conversion, aside from being real-time, not be superior?
Shane Ross
June 23, 2014 at 5:55 pmYes, that is a hardware conversion, and yes, it’s better than just using SD in an HD sequence.
Shane
Little Frog Post
Timothy Lydon
June 26, 2014 at 1:09 amShane,
Thank you so much for responding. I created a master HD project and another SD project. I linked my SD videos and transcoded them using 1:1 MXF. However, I am not sure how to “drag the bins over on the finder level” I tried to import the bins from the SD project but was told “The file format is not supported for import”
Have you seen this before?
Timothy
John Pale
June 26, 2014 at 3:25 am[Timothy Lydon] “However, I am not sure how to “drag the bins over on the finder level” I tried to import the bins from the SD project but was told “The file format is not supported for import”
“You are making this out to be more complicated than it is. Literally all you need to do is go into the project folder of the SD project and drag the bins you want into the project folder of the HD project in the Finder….not within Avid. Avid does not need to be running to do this.
Timothy Lydon
July 1, 2014 at 6:33 pmYes, I was making it more complicated than I had to. Thank you very much for your patience 🙂
