Activity › Forums › Apple Final Cut Pro Legacy › HD and MiniDV in FCP
Posted by Nora199 on June 23, 2006 at 11:36 pmHi there, does anyone know if both HD and MiniDV be edited in the same project together in Final Cut Pro HD4.5? thank you.
Max Frank replied 20 years, 3 months ago 3 Members · 4 Replies -
Walter Biscardi
June 23, 2006 at 11:39 pmSure, but you’ll have to render whatever doesn’t match your Sequence. Edit in DV, you’ll need to render the HD. Edit in HD, you’ll need to render the DV.
You can purchase an AJA Kona 3 and convert your DV to HD or HD to DV so everything will match.
Walter Biscardi, Jr.
https://www.biscardicreative.comDirector, “The Rough Cut”
https://www.theroughcutmovie.comNow Posting “Good Eats” in HD for the Food Network
Nora199
June 24, 2006 at 5:06 amHi Walter,
Thank you for this information. Have you ever converted DV to HD and if so how does it look in terms of quality compared to something actually shot in dv?thanks again
Nora -
Walter Biscardi
June 24, 2006 at 3:06 pm[Nora199] “Have you ever converted DV to HD and if so how does it look in terms of quality compared to something actually shot in dv?”
Depends on how well the footage was shot and if it was shot anamorphically. I get pretty good results on my Kona 3 and if I need something more, I go to a terranex shop.
Max Frank
June 25, 2006 at 9:09 amYou may also want to check out:
https://www.kenstone.net/fcp_homepage/review_instant_hd_douglas.html
Wayne
