Activity › Forums › Adobe After Effects › HD 4:3 no black bars
  • HD 4:3 no black bars
    Posted by David Hueso on January 11, 2010 at 12:48 am
    I'm working on a commercial HD 1920 x 1080 (1080p 24fps) _ in after efects and am creating animations …. But I have to deliver work
    In Ntsc 4:3 without black bars above and below … 16:9..
    I do not want to work twice as I am working on a composition
    HD 1920 x 1080 and I will not return to work Las new animations
    A 720×480..Ntsc
    As I?
    To create a new composition in 720 x 480 ntsc and methodological Hence the composition
    Full HD … Lose the sides where I have very important things for the animation …
    I do not want to miss…
    There any way to export directly from the component HD 1920 x 1080
    720 x 480?
    As shown in the picture attached…
    davidhueso Ecu
    Walter Soyka replied 16 years, 8 months ago 4 Members · 3 Replies
  • Brian Charles
    January 11, 2010 at 1:56 am
    If I understand your question, you need to produce a 4×3 version of a 16×9 animation without any letter boxing or side pillars.
    A simple way to do this is to put the 16×9 Composition (or better still the 16×9 render) into a 4×3 NTSC Composition and scale it to fit the height. Then render.
  • Steve Roberts
    January 11, 2010 at 2:03 am
    Your original comp is 16×9. Wide.
    The client wants 4×3, which is 16×12. Narrow.
    You made a mistake by working in 16×9, or your client changed the specs late in the project.
    You have two choices if you want no black bars:
    1) squeeze the original so it all fits on the screen. This will look strange.
    2) cut off the left and right sides of the original. This will lose image on the sides.
    Here is one way to render:
    1) drag the comp into a new DV NTSC comp.
    2) scale so the original comp fills the new comp (cmd+opt+f), or scale so the original comp is cut off on the sides (cmd+opt+shift+G).
    If you can convince the client to use black bars, then scale the original comp (in the new comp) using cmd+opt+shift+H.
    Render the DV NTSC comp.
  • Walter Soyka
    January 11, 2010 at 12:39 pm
    [david hueso] “I have to deliver work In Ntsc 4:3 without black bars above and below … 16:9.. “
    Is anamorphic 16:9 delivery an option? Here, a 16:9 comp is squished horizontally and then re-expanded on playout. This will be up to your broadcaster, so make sure you have specs from them.
    Also, you need to consider the different frame rates; you were working in 24 fps (perhaps truly 23.976), and you need to deliver 29.97 for NTSC. Do you intend to add a pull-down, resample your work in AE, or do a standards conversion?
    Walter Soyka
