Activity Forums Apple Final Cut Pro Legacy HD 24p firewire output problems
  • HD 24p firewire output problems
    Posted by Steve Powell on August 2, 2005 at 12:03 pm
    I am editing a project using DVCpro 24 (23.98) using a Panasonic HD 1200a deck connected via firewire. The video goes in fine and is fine in the sequence set at 23.98. However, when I try to output back to the deck the picture is always jumping and very distorted, it sort of looks like it is completely out of sync. I have tried checking every setting possible and even changing the firewire cable nothing works. The timeline playback often hangs up when the firewire is attached and is playing back through the deck. Help!
    I Have a Dual G-5 with FCP 4.5
    Walter Biscardi replied 21 years, 1 month ago 5 Members · 5 Replies
  • Andy Mees
    August 2, 2005 at 12:14 pm
    hi Steve
    do you have the “Abort ETT/PTV on dropped frames” setting checked?
    if not it could be that you’re dropping frames … perhaps you need to force the audio to render first
    try choosing Sequence > Render Only > Mixdown
    hope it helps
    Andy
  • Walter Biscardi
    August 2, 2005 at 12:28 pm
    Are you watching the playback during recording? If so, you need to view the tape AFTER it’s recorded. There is an issue with the 1200A showing black, out of sync appearing video during record using Firewire. You need to play the video back after it’s recorded to check it.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
  • Harry
    August 2, 2005 at 2:36 pm
    You might want to check out a posting from August 1st called “Losing Sync during Master to tape” a few lines below this post.
    Regards,
    Harry
  • Jeremy Garchow
    August 2, 2005 at 6:31 pm
    From page 35 of the manual that you can download here:
    https://tinyurl.com/yqg4u
    When
  • Walter Biscardi
    August 2, 2005 at 6:37 pm
    [JeremyG] “Get yourself an HD capture card and monitor though HD-SDI instead of firewire.”
    actually, with the Kona 2 you can also monitor via Component which is what I do here.
