Activity Forums Maxon Cinema 4D HD 16 x 9 question
  • HD 16 x 9 question
    Posted by Jason Richards on May 15, 2007 at 3:57 pm
    This might sound silly but… Our station is HD 1920x1080i. I always render out my stuff 1920×1080 and select Automatic for film format which is 1920×1080. Should I actually be choosing HDTV to get the 16 x 9 aspect or does that not matter since it’s set 1920×1080. I know it’s confusing, but basically just because it says 1920×1080 doesn’t mean that it’s actaully 16 x 9 right ? or any I losing my mind again. Oh, and everything I’ve rendered out in the last 6 months has looked great in HD…
    Thanks for any light on this topic
    JR
    John replied 19 years, 3 months ago 3 Members · 2 Replies
  • Adam Trachtenberg
    May 18, 2007 at 5:51 pm
    The only thing that really matters is the pixel dimensions. If it ain’t broke don’t fix it. 🙂
  • John
    May 30, 2007 at 11:56 am
    To answer your question.. you are correct. Just because you select 1920×1080 pixels for the ‘resolution’ does not necessarily mean that your render will have a 16×9 aspect ratio. The ‘pixel’ ratio value(s) that appear in the Render Settings dialog determine the overall aspect ratio. The default is 1:1 which gives you square pixels in the final render.
    So.. If you choose a resolution of 1920×1080 and leave the pixel aspect ratio as 1:1, then you will get a 16×9 output. This is because 1920 div by 1080 is the same as 16 div by 9 (or 1.778). Thus, your settings have been working just fine because HD is natively 16×9 and happens to use square pixels.
    As a comparison.. if you were working with DV footage that is natively 720×480 pixels, you would need to enter a pixel aspect ratio of 1.185:1 (rather than 1:1) to get a final render that is 16×9. Why? The DV video standard uses non-square pixels for display. The data is stored with a square pixel aspect ratio of 3:2 (720 div by 480) but is displayed with either a 4:3 or 16:9 aspect ratio. So.. to get a 4:3 image, DV pixels must be squeezed horizontally and to get a 16:9 image they must be stretched horizontally.
    To determine the correct pixel aspect ratio for 4×3 DV footage, you divide the desired aspect ratio of 1.333:1 (that’s 4 div by 3) by the native (square) pixel aspect ratio of 1.5:1 (that’s 720 div by 480, or 3:2). This gives you 0.889:1.
    Likewise, to determine the correct pixel aspect ratio for 16×9 DV footage, you divide the desired aspect ratio of 1.778:1 (that’s 16 div by 9) by the native (square) pixel aspect ratio of 1.5:1 (that’s 720 div by 480, or 3:2). This gives you 1.185:1.
    BTW.. I think it’s best to set the ‘Film Format’ popup in the Render Settings dialog to ‘Automatic’ which basically turns this feature off. All C4D needs to know is the final resolution and the pixel aspect ratio. As far as I can tell, the ‘Film Format’ option is just a data entry convenience that forces the resolution you enter just above to be of a specific aspect ratio. But that is confusing because the ratio of width to height of the image is not necessarily the ratio that it will be displayed at. It is for square pixel formats (like HD) but not for non-square pixel formats (like DV).
    Hope that helps. John
