Activity › Forums › Adobe After Effects › HD 1280X720P H.264 render settings
  • Steve Roberts
    February 1, 2008 at 8:50 pm
    Set up an AE comp using one of the two DVCPRO HD presets, depending on the desired frame rate. Your Render Settings should be Best Settings, and your Output Module should be Lossless, or Quicktime Animation. Render that, then open the result in Quicktime Player and use it to Export to H.264.
