Activity Forums VEGAS Pro HD 1080p w/ non-HD child
  • HD 1080p w/ non-HD child
    Posted by Tyson Onaga on August 27, 2009 at 4:31 pm
    I found that I can nest a non-HD project into an HD 1080p project. The parent is HD 1080-60i while the child is NTSC DV at 1440×960. When I examine File.Properties, I notice that other than the Width and Height, the only other field that changes between HD 1080-60i and Custom NTSC DV (1440×960) is Pixel Aspect Ratio.
    HD 1080-60i says 1.0000 (Square)
    Custom NTSC DV (1440×960) says 0.9091 (NTSC DV)
    As far as I can tell, I don’t see any strange artifacts by doing this. When I preview, I see the child being played at 1440×960 inside a 1920×1080 frame and positioned via Track Motion correctly. The “black” areas will be filled in later.
    So, are there issues nesting projects where the Pixel Aspect Ratio is/are different? Thanks in advance.
    Tyson Onaga replied 17 years ago 1 Member · 0 Replies
  • 0 Replies
