Activity › Forums › Panasonic Cameras › HD 1080p on P2
HD 1080p on P2
Posted by Ivan Kacer on October 3, 2005 at 1:21 amWould Panasonic in future include upcoming HD 1080p in cameras?
Rodrigo Lizana replied 20 years, 10 months ago 5 Members · 5 Replies -
Jeremy Garchow
October 3, 2005 at 2:24 amA list of supported formats from the panasonic HVX200 webpage:
1080/60i, 1080/24p, 1080/30p, 720/60p, 720/24p, 720/30p, 480/60i, 480/24p, 480/30
Ivan Kacer
October 3, 2005 at 11:04 amI saw that, but other informations, if we talk about HVX 200 state 1080i/720p, so I’m a bit confused.
Lawrence Bansbach
October 3, 2005 at 1:21 pmThere is no 1080p format supported in DVCPro HD except 1080p24 and 1080p30, which are encoded as part of a 60i stream. With 1080p24, the 24 progressive frames are converted into 48 fields, 12 of which are duplicated to bring the number up to 60. This means that 6 frames per second are each synthesized from one field from each of two successive original frames. With 1080p30, the 30 progressive frames are converted into 60 fields.
