Activity › Forums › Avid Media Composer › hd – 1080 59.94i /50i workflow
  • hd – 1080 59.94i /50i workflow
    Posted by Geraint Pari huws on November 26, 2007 at 11:09 pm
    HI.
    I’m sure the answer’s in the archives somewhere so I apologise for repitition beforehand…
    Off line – on-line project looming.
    Programme delivery will be for UK.
    HDcam 1080 50i + SD digibeta. (PAl)
    Rushes will be mix of HDcam 1080 50i, and 1080 59.94i. + some HDV 1080 50i thrown in.
    Offline will be Avid MC of some sort,
    conform/grade/master symphony nitris.
    The HDcam 50i I was intending to load sd sdi from a Jh3 for offline and then conform and playout to SRW5500.
    The HDV I would load sd sdi for off-line and then conform HD from a HVR500.
    What’s the best workflow considering the 59.94i footage?
    thanks in advance
    AMHEUS
    Geraint Pari huws replied 18 years, 10 months ago 2 Members · 2 Replies
  • Bill Stephan
    November 27, 2007 at 9:40 pm
    Plan A: If you don’t have large amounts of 1080/59i footage, then standards convert to an HDCAM or SR 1080/50i. If there is much 1080/59i footage, especially if it will live together in one large segment (or many smaller segments) of the program, you might like:
    Plan B: Off-line and on-line the 1080/59i footage into a 1080/59i edit master and standards convert that to 1080/50i. Then drop into the final 50i off-line and on-line as needed.
    A lot depends on how you need to organize things in the final production.
    Bill Stephan
    Senior Editor/DVD Author
    USA Studios
    New York City
  • Geraint Pari huws
    November 28, 2007 at 6:54 pm
    cheers
    great straight answer, was intending on the standards convert since whole prooject depends on intercut footage, wanted to check I wasn’t missing something before spending a fortune.
    thanks again
    amheus
