Activity Forums Apple Final Cut Pro Legacy HCX and DVX footage in same sequence…
  • HCX and DVX footage in same sequence…
    Posted by Andrew Paul bowser on May 11, 2007 at 8:08 am
    Hi!
    I am trying to intercut footage shot in native 16:9 from an HVX200 camera with footage shot full frame with a DVX100.
    What should my sequence or timeline settings be at in FCP? Presently when I bring in DVX100 footage, it shrinks to a ridiculous size.
    Thank you! I Have a deadline!
    -Andrew
    Walter Biscardi replied 19 years, 4 months ago 2 Members · 2 Replies
  • Andrew Paul bowser
    May 11, 2007 at 8:11 am
  • Walter Biscardi
    May 11, 2007 at 11:36 am
    [andrew paul bowser] “I am trying to intercut footage shot in native 16:9 from an HVX200 camera with footage shot full frame with a DVX100.
    What should my sequence or timeline settings be at in FCP? Presently when I bring in DVX100 footage, it shrinks to a ridiculous size.”
    Did you shoot the HVX in HD? That’s what it sounds like so what you’re seeing is SD 720×486 full size inside an HD timeline.
    What are the clip settings for the HVX clips? If it says 960×720 or larger, that’s HD footage, not 16:9 SD anamorphic. If so, you’ll have to scale up the DVX footage or shrink down the HD footage.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Broadcast and independent productions.
    All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
