Activity › Forums › Panasonic Cameras › HCVPRO-HD converted to ACVHD?
Posted by Bill Parsons on March 15, 2012 at 12:40 amI have a Panasonic HPX250 that I usually set to shoot in HVCPRO-HD and I am interested in converting the footage to AVCHD. I have a friend who shoots with cameras that produce AVCHD.
How would I convert from the P2 camera to AVCHD? Do I need to shoot some other format on the HPX250, will I need to convert in FCP, or am I unable to make this conversion?
Many thanks, Bill
Noah Kadner replied 14 years, 6 months ago 3 Members · 5 Replies -
Shane Ross
March 15, 2012 at 5:34 pmWhy take your superior format and make it a far INFERIOR one?
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Noah Kadner
March 16, 2012 at 1:28 amYeah that would be a major quality hit, plus good luck recreating the exact flavor of AVCHD footage the friend uses. If this is presumably for editing the two together- any modern NLE will do this step for you and mix accordingly at best possible quality.
Just turn over your DVCPROHD footage as complete copies of the entire card structure from your camera and let them take it from there. Or if you want to be extra nice- convert to a more robust format like DNxHD, CineForm or ProRes- depending on where you’re coming from. But finding out a bit more on the why you need this would help.
Noah
Call Box Training.
Featuring the Panasonic GH2 and Panasonic AC160/130. -
Bill Parsons
March 16, 2012 at 1:33 amAs you both suggest, it’s not my choice. I thot it would make my friend’s life easier if I converted to his format, even tho it’s lower res.
He tells me that FCP doesn’t speak AVCHD and that he uses a converter.
I agree that letting him sew them together is easierThanks for the responses.
Best, Bill
Shane Ross
March 16, 2012 at 3:04 amFCP speaks AVCHD the same way it speaks P2…the footage needs to be accessed via Log and Transfer and brought in that way. FCP doesn’t deal with either format natively.
Tutorial on this whole process with tapeless:
Tapeless Workflow for FCP 7 Tutorial
Give them the card backup, as I outline in the video. Do not try to make it AVCHD in any way, shape or form.
Shane
Little Frog Post
Noah Kadner
March 17, 2012 at 1:17 amYeah the friend is mistaken- if he gets your footage as card archives from the camera itself he’ll be able to ingest as DVCPROHD directly and be good to go from there. File>Log and Transfer. Just make sure to copy your footage as the entire structure from the card, each card into its own discrete folder and it will be good to go.
Noah
Call Box Training.
