Activity › Forums › Adobe After Effects › Having trouble with the video copilot plugin Twitch
  • Having trouble with the video copilot plugin Twitch
    Posted by Rafael Ribeiro on July 14, 2014 at 6:58 pm
    I have this composition with a red solid in 3d space using the twitch slider ( rgb split) on it and even though I can see the effect taking place, there’s one frame that doesn’t render and the preview stops. If I turn off the effect, the composition will render properly. Any idea what might be causing this?
    Michael Szalapski replied 12 years, 2 months ago 2 Members · 2 Replies
  • Rafael Ribeiro
    July 14, 2014 at 11:40 pm
    I’m only using solids and an illustrator file in the composition ( also, a light, camera, etc, but all things provided inside after effects).
  • Michael Szalapski
    July 15, 2014 at 5:03 pm
    What version of AE are you using (down to the last decimal)?
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
