Activity Forums Adobe After Effects Having trouble with cc split and two audio tracks
  • Having trouble with cc split and two audio tracks
    Posted by Nate Liebermann on June 10, 2014 at 1:46 am
    I am using the CC Split effect to animate two different mouths on a live video. My problem is that the second mouth for some reason is picking up on the audio amplitude from the first mouth so that it moves while the first one is moving in addition to moving with its own audio. Any thoughts?
    Much appreciated.
    Walter Soyka replied 12 years, 2 months ago 3 Members · 2 Replies
  • Todd Kopriva
    June 10, 2014 at 2:40 am
    There’s a lot more detail in the first instance of this duplicate thread:
    https://forums.creativecow.net/readpost/2/1051912
    After Effects team blog
  • Walter Soyka
    June 10, 2014 at 1:36 pm
    Thanks, Todd, for pointing to the context in the duplicate thread.
    Nate, keyframes still count for expression references even after the out point of a layer. You should delete the keyframes generated by audio to keyframes on a layer that are outside of the range of time you want to use.
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
