Activity › Forums › Apple Final Cut Pro Legacy › Having trouble with capturing from HDV to ProRes via firewire
  • Having trouble with capturing from HDV to ProRes via firewire
    Posted by Michael Escher on December 22, 2007 at 6:52 pm
    I’m using the methodology recommended in Chris Poisson’s article “Capture HDV to ProRes over Firewire in FCP6.” Things are going pretty well, all things considered.
    One issue that I found a workaround for: I’m running a dual core 3ghz intel machine with a kona LHe card (not that it matters much capturing via firewire) and found that after each tape that I needed to re-boot the computer otherwise I got a “you have reached the end of the tape” error message when I tried to capture a second tape. This is coming from a canon camera with material shot at “24” frames a second.
    I have one problematic tape that I am trying to capture for the third time that when it gets close to the end of the tape FCP crashes and when I look at the capture scratch folder it didn’t get anything from that tape. I’m baby sitting and watching the tape through the whole capture now to see if there is a time code break.
    Has anyone else had this sort of problem? What happens with this sort of capture strategy when the computer encounters a time code break?
    Michael Escher
    Michael Escher replied 18 years, 9 months ago 1 Member · 1 Reply
  • Michael Escher
    December 22, 2007 at 7:08 pm
    UPDATE: I reached near the end of the tape (a little over 58 minutes) and FCP crashed again, even without a time code break. I’m gonna try to hit escape just before 58 minutes and see if the program will at least retain that much of the capture.
