Activity › Forums › Apple Final Cut Pro › Having trouble with an XML export [FCPX to Vegas Pro 14]
  • Having trouble with an XML export [FCPX to Vegas Pro 14]
    Posted by Sam Benson on September 24, 2018 at 4:43 am
    Hi there,
    I’m working on a project for a client where I’m doing the bulk editing in Final Cut Pro X and then bringing everything into Vegas so that they can make some final touch ups on their end with Vegas and view the whole timeline. Unfortunately, I’m not able to get Vegas to import everything into a nice timeline format. I did some searching and found a weird workaround with Vegas and Davinci for importing into Premiere Pro, so I figured I should try that.
    The XML I made in FCPX worked in Davinci – the timeline is rebuilt and everything. I decided to try and export another XML file as well as an AAF file to see if that might be a good fix, but no luck. I realize it’s a bit of a weird issue, but any help would be appreciated.
    Jeff Kirkland replied 8 years ago 2 Members · 1 Reply
  • Jeff Kirkland
    September 24, 2018 at 8:38 pm
    What’s happening in Vegas when you do the import? Where’s it failing? And have you tried sending it a simpler test project? And I guess, the more obvious question, is that version of Vegas compatible with the version of fcpxml that you’re sending it?
    Jeff Kirkland | Video Producer & Cinematographer
    Hobart, Tasmania | Twitter: @jeffkirkland
