Activity › Forums › VEGAS Pro › Having trouble upgrading to Vegas 8.1
  • Having trouble upgrading to Vegas 8.1
    Posted by Don Landis on November 22, 2008 at 11:52 pm
    My system is a Quad core running 64 bit Vista. 8 Gb ram.
    I have version 8.0b Vegas running now with no problems. I downloaded the upgrade file for version 8.1 because it is for 64 bit Vista.
    The problem I have is it never makes it past the a certain point in the install process and gives me an error message as follows:
    “An error occurred attempting to create the directory C:\Program Files (x86)\Sony\Shared Plug-Ins. ”
    First of all I am logged in as Administrator and have verified I have “Full Control” Privileges. In addition, I was able to upgrade the DVD Architecture 4.5 to 5.0a with no trouble. I also installed Sony Picture Motion Browser with no problem. I also went into that directory and wrote some files to it. Changed those file names and back again to confirm I had full control and privileges.
    Don Landis replied 17 years, 10 months ago 2 Members · 2 Replies
  • Stephen Mann
    November 24, 2008 at 4:56 am
    You will get this Windows error if another program has a file in the target directory open. Make sure that all applications are closed and try again.
    OR
    Try renaming your current shared folder to something else. If you can’t, then you need to figure out why. If you can, then the install should create a new one. Then just copy the contents of the old folder to the new and delete the old folder.
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Don Landis
    November 29, 2008 at 8:48 am
    Finally got both 8.1 and 8.0c loaded. Appears that the permissions were incorrect in the Sony/Vegas 8.0 folder and sub folders. It was a long and difficult process to correct each file. Some of the sub folders were able to be corrected using inherit from parent folder but many I had to go in and manually reassign the ownership first and then reset the permissions to Full control second. Once this was done I was able to do the two upgrades.
    A few of my plugins don’t seem to work with 8.1 but with 8.0c loaded I think I’ll have what I need.
