Activity › Forums › Adobe Audition › Having Trouble Please help
  • Having Trouble Please help
    Posted by Bige502 on September 21, 2006 at 1:35 pm
    Hi guys im having trouble recording vocals my first question is how do i prevent my vocals from coming out of the sub level is there a certain frequency they need to be on or what? My second question is this i’m a little strap for cash so i dont have a interface i was wondering do i need a to run my mic through an interface because right now its running straight to the computer and for some reason i have to record with the volume real low because the sound bleeds over into the track im recoding on. THANKS IN ADVANCE TO ANYONE WHO CAN HELP ME
    Willie Toth replied 20 years ago 2 Members · 3 Replies
  • Willie Toth
    September 21, 2006 at 2:40 pm
    OK, I need to know a couple of things …
    Do you have a soundcard or are you using onboard sound
    Have you checked your windows mixer to see where the volume is set
    What kind of mic are you using and which port is it plugged into
    If you are not using headphones or your volume in the headphones is too
    high you will get a bleed, this is where a compressor limitor can
    really help
    You can pick up a mixer like the eurorack ub120 4fx by berringer for
    less than 70 bucks, it’s not the greatest but it is better than
    nothing
    As long as you are doing a track at a time you are fine like you are until you can afford some outboard gear you just need to tweak it a bit ……… WILLIE
  • Bige502
    September 21, 2006 at 9:01 pm
    i’m using the onboard sound card i think its sigmatel and i have it olugged in the mic port
  • Willie Toth
    September 22, 2006 at 1:49 am
    Did you check volumes on the window mixer? Are you using headphones?
