Activity Forums Adobe After Effects Having Trouble Importing a PSD file into AE CS5
  • Having Trouble Importing a PSD file into AE CS5
    Posted by Andreas Sizynski on September 4, 2011 at 11:42 pm
    Hey all, so I have been repeatedly trying to import a PSD file into AE, but AE only loads other files that:
    1) have the jpeg icon next to them, not the PSD icon
    2) Are not relevant to this composition. They’re from an older PSD file with a 944×646 resolution while this composition is 1080p and so are the PSD files that should be importing.
    I have tried to import this PSD file several times now, using the Import > File
    And then choosing the “Composition” & selecting Editable Layer Styles
    I really am at my wits end.
    An Artist interested in the past, stuck in the present.
    Andreas Sizynski replied 14 years, 12 months ago 3 Members · 3 Replies
  • Ben G unguren
    September 5, 2011 at 1:09 pm
    That sounds really odd. What OS are you working on? What version of AE?
    Here are a few thoughts for variations on importing technique (shots in the dark):
    Have you tried opening your PSD in photoshop and saving a copy with a newer version of PS?
    Have you tried dragging the PSD file into your project window (instead of FIle–>Import…)?
    Have you tried importing without the “Editable Layer Styles” enabled?
    Ben Unguren
    Motion Graphics & Editing
    http://www.mostlydocumentary.com
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Chris Tompkins
    September 5, 2011 at 5:21 pm
    OPen it up in PhotoShop, Make sure it’s not CMYK color space.
    Save as PSD
    Save as Tiff
    Chris Tompkins
    Video Atlanta LLC
  • Andreas Sizynski
    September 6, 2011 at 4:11 am
    Hey ben, I appreciate your response. I did end up just Re-saving the file as something completely different. That did the trick, but yes it was very odd.
