Activity Forums Adobe Premiere Pro Having Trouble Exporting 4K Video Resolution
  • Having Trouble Exporting 4K Video Resolution
    Posted by Mark Williams on June 17, 2020 at 6:11 pm
    I’ve watched countless videos in order to find a solution to render my video in 4k resolution. I changed the sequence settings to match the camera settings of my canon m50. I also customized my rendering settings. Some of the things I changed were:
    Format: H.264
    Frame Rate: 25 (3840×2160)
    Profile: High
    Level: 5.2
    Bitrate Encoding: CBR
    Target Bitrate: 200
    I also checked the Maximum Render Quality box and the Render at Maximum Depth box. My friend got me this version of premiere pro 2020 for free, maybe I’m using his account… not sure. But maybe it’s because of that? So not sure if I have to purchase it. I heard the having the adobe media converter may help? Could someone help me figure out a solution? Thanks
    Daniel Carranza replied 6 years ago 2 Members · 1 Reply
  • Daniel Carranza
    August 31, 2020 at 1:08 am
    Hello, Mark Willians.
    Your project settings seem ok. Did you try to render your sequence before trying to export it? If not, try doing that. Sometimes our sequences are so heavy with effects and stuff like that, that even Adobe Premiere has a hard time handling it. If the problem continues even after rendering the sequence, I suggest that you create a new project and use it to reopen your sequence inside of it. After that, you should be able to export it without problems. That works for me all the time. If everything that I suggested don’t work, you should try exporting your sequence in a different way. There’s a plugin available called AfterCodecs. It should help you to fix those problems. Check it out: https://www.autokroma.com/AfterCodecs – It allows you to export your videos following your desired format.
    I hope it works for you.
    To any moderator coming to my post: I’m not making any advertisement regarding products or whatsoever. I’m just trying to help a colleague by suggesting him some alternatives that would prevent him from facing more problems with the Adobe softwares.
    Best wishes,
    Daniel Carranza
