Activity Forums Apple Final Cut Pro Legacy Having to render when dragging Prores Proxy clips to Timeline
  • Having to render when dragging Prores Proxy clips to Timeline
    Posted by John Northrup on February 10, 2011 at 9:25 pm
    I ingested clips from an EX1, and used the Sony plug-in in FCP to transcode them to MPEG2, since this seemed to be unavoidable. Then I transcoded them in compressor to Prores Proxy. Before I connected the project files to the proxy clips, I had been editing the MPEG2 clips. When I dragged the MPEG2 clips into the timeline, I never had to render them to watch them.
    However, when I drag the Prores Proxy clips into the timeline, I always get a red “needs render” bar. Is this always the case? I assume I have some settings that are wrong, but I haven’t been able to sort it out.
    Jeff Greenberg replied 15 years, 7 months ago 3 Members · 2 Replies
  • Anthony Bari jr.
    February 11, 2011 at 6:54 am
    1 of a few things,
    1) Sequence settings>CMD+0 (match your codec)
    2) If your on a laptop, check your energy saving setting make sure your on High Performance
    3) RT setting make sure you are not on safe RT by accident
    I hope that helps.
    *Production*Post-Production*
    Apple Certified Instructor (Final Cut Pro 7)
    “Semper Fi USMC”
  • Jeff Greenberg
    February 11, 2011 at 3:05 pm
    [John Northrup] “I ingested clips from an EX1, and used the Sony plug-in in FCP to transcode them to MPEG2, since this seemed to be unavoidable”
    Is there a reason you’re not using Log and Transfer with the sony plugin?
    Best,
    Jeff G
    Apple Master Trainer
    Avid Cert. Instructor DS/MC
    Avid & Color Videos Vasst.com
    Compressor Essentials Lynda.com
