Having to “Render for Playback” simple audio changes??
I am having to “Render for Playback” all of my audio filters. I have a sequence of video with stereo audio that I digitized from my DV deck and I am trying to apply some audio filters to remove hum and clean up the audio but I have to Render the Audio for Playback. I read in the Manual (user volume III) and it speaks of a way to loop the sequence over and over as you make adjustments to the filter to real time HEAR the effects. I can’t do that. If I make any change at all and I have to re-render for playback. The capture and sequence presets are QuickTime Video Settings – DV/DVCpro-NTSC with the audio set to 48 KHz with a depth of 16-bit and the Channel Grouped. I’m using FCP 6.0.6 on a MAC with 2 x 3.2 GHz Quad-Core Intel Xeon with 18 GB 800MHz DDR2 FB DIMM. This is not a weak machine and I believe my capture and my sequence presets match. What am I missing? It just seems that my FCP has lost some of it’s power. I have also had some uncompressed .MOV files that my machine can’t play. Even after I render the video it can play it. I can scrub through it but I can’t play it. Thanks for listening.
Tom
