Activity › Forums › Apple Final Cut Pro Legacy › having to render all when putting clips in timeline
  • having to render all when putting clips in timeline
    Posted by Sarah Leisdovich on December 1, 2006 at 6:32 pm
    I have this problem…
    We filmed footage with a Sony handycam HDR-HC1E PAL, in wide-screen format (16/9). We did not use the High Definition tapes, but the normal Sony miniDV tapes. We captured it succesfully with capture presets in audio/video settings ‘DV PAL 48 kHz Anamorphic’. Also for the sequence presets in audio/video settings, we chose the same settings. For the sequence settings in the sequence tab we put “CCIR 601 PAL Sq. (4:3), Anamorphic, Editing Timebase:25, Compression: DV PAL…
    However, when we put the clips into the timeline the system asks to render everything (a red stripe occurs above in the timeline).
    Why is this?
    Should I change the settings (I already tried out a lot of different combinations but nothing seems to work out)?
    I am using Final Cut Pro 4,5HD on a Powerbook G4.
    Thanks…
    Sarah
    David Smith replied 19 years, 10 months ago 3 Members · 4 Replies
  • David Smith
    December 1, 2006 at 7:01 pm
    [ojo de pollo] “For the sequence settings in the sequence tab we put “CCIR 601 PAL Sq. (4:3), Anamorphic, Editing Timebase:25, Compression: DV PAL..”
    Sarah,
    What happens if you set the sequence’s Aspect Ratio to CCIR 601 / DV PAL (5:4)?
  • Walter Biscardi
    December 1, 2006 at 7:03 pm
    [ojo de pollo] “Also for the sequence presets in audio/video settings, we chose the same settings. For the sequence settings in the sequence tab we put “CCIR 601 PAL Sq. (4:3), Anamorphic, Editing Timebase:25, Compression: DV PAL…
    However, when we put the clips into the timeline the system asks to render everything (a red stripe occurs above in the timeline).”
    So you changed the Sequence settings are they are left alone as they were when you first selected it?
    Your Sequence obviously does not match your clips, that is why you’re having to render.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Food Network’s “Good Eats”
    HD Editorial for “Assignment Earth”
  • Sarah Leisdovich
    December 1, 2006 at 7:30 pm
    This indeed seems to do it! I just thought 5/4 was such a strange format… I would never have thought…
    Thanks a lot!
    Sarah
  • David Smith
    December 1, 2006 at 8:26 pm
    Ah, good, glad that worked. It can be very confusing, the issue here is that your DV footage uses non-square pixels.
