Activity Forums Apple Final Cut Pro Legacy Having to render a simple dissolve… and every single transition.
  • Having to render a simple dissolve… and every single transition.
    Posted by Bert Delgado on December 27, 2010 at 8:18 pm
    I do not remember having to render a simple dissolve in Final Cut Pro 7.
    Something must have had been changed. I now that I had some questions about audio and the Apple technician NOT the Final Cut Pro tech support, told me to do a reboot while pressing four different keys.
    God knows what that did… but I do not know.
    My setting are:
    Apple ProRes 422 at the Sequence and the same at capturing.
    I am using a Panasonic AVCHD camera and although I try to set the Log and Capture to AVCHD, it seems to refuse to take it.
    Is this all related? I am rendering almost everything I do as far as transitions go.
    Thanks for info
    Bert
    Ian Liuzzi-fedun replied 15 years, 7 months ago 5 Members · 4 Replies
  • David Roth weiss
    December 27, 2010 at 10:42 pm
    Typically that behavior means that your sequence settings do not properly match your media. Try opening a new sequence and let FCP change the settings to match the media when you drop the first clip on the timeline.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    https://www.drwfilms.com
    A forum host of Creative COW’s Business & Marketing and Apple Final Cut Pro forums. Formerly host of the Apple Final Cut Basics, Indie Film & Documentary, and Film History & Appreciations forums.
  • Paul Jay
    December 27, 2010 at 11:04 pm
    Drag a clip in a empty timeline. Then it asks to Match your media. Say Yes.
    Still the same?
  • Walter Biscardi
    December 28, 2010 at 2:35 am
    [Bert Delgado] “My setting are:
    Apple ProRes 422 at the Sequence and the same at capturing.”
    Simply change your Easy Setup to match your Sequence Settings.
    [Bert Delgado] “I am using a Panasonic AVCHD camera and although I try to set the Log and Capture to AVCHD, it seems to refuse to take it.”
    It will convert everything to ProRes. That’s the editing codec you want to use.
    Walter Biscardi, Jr.
    Editor, Colorist, Director, Writer, Consultant, Author, Chef.
    HD Post and Production
    Biscardi Creative Media
    “Foul Water, Fiery Serpent” Winner, Best Documentary, LA Reel Film Festival.
    Blog Twitter Facebook
  • Ian Liuzzi-fedun
    January 4, 2011 at 4:40 am
    Just double check the actual format of your media when captured.
