Activity › Forums › AJA Video Systems › Having sync Issue with ioHD, Cabling/Setup might not be correct
Craig Bernstein replied 17 years, 3 months ago 4 Members · 26 Replies
Jeremy Garchow
November 7, 2008 at 4:46 pm[Mike Patrick] “Is there a possibility that the Avid is outputting something onto the tape thats causing the frame to shift around when i play it back on my deck? “
No, but I’d suspect the deck as a possible source of weirdness. Sorry man, these types of things are very hard to trouble shoot over email. If you think that you have everything setup properly, then I would suspect the deck. If you other tapes there that were output by something other than your Avid, and if those work okay, then I’d suspect the tapes.
Jeremy
Mike Debbie
November 7, 2008 at 4:53 pmI didn’t mention this earlier, but i called and left two messages with the AJA tech services and received no call back on my issue so I appreciate all the help as well as the timeliness of your replies.
Mike Debbie
February 27, 2009 at 9:28 pmJust wanted to leave an update on the issue. Turned out to be the video tracking dial on the deck. I just so happen to be noodling around with the dial when suddenly the think black bar disappeared. Problem solved. It always turns out to be the simplest things.
Craig Bernstein
May 22, 2009 at 4:50 pmNot sure how old this thread is but:
Getting back to the reference disappearing when ‘Log and Capture’ is opened:
Why would the ioHD reference the incoming video when the AJA control panel is set to GenLock ‘Reference in’ (and not ‘Video in’).
I have tri-sync feeding all my components’ (HDCAM, DVCPRO HD, AJA ioHD) reference ins with 75ohm terminators on the outs..
Thx in advance for any insight
Jeremy Garchow
May 22, 2009 at 5:07 pm[Craig Bernstein] “Why would the ioHD reference the incoming video when the AJA control panel is set to GenLock ‘Reference in’ (and not ‘Video in’). “
As it’s just the way it works and it doens’t need anything else. The reference will work on output for your layoffs/mastering.
