Activity Forums Maxon Cinema 4D Having some troubles with cloth
  • Having some troubles with cloth
    Posted by Brian Smith on May 20, 2008 at 11:19 pm
    I am trying to get a scroll unfurl and roll out over a floor. I have the unfurl down fine, I’m just using a Bend deformer. But for some reason, that seems to disable my floor object. It has a collider tag on it. I tried another plane with a cloth tag on it in the same scene, and it behaved just fine. The problem seems to lie in the deformer tag.
    Any thoughts? Or other ways of having something unfurl and bounce off of a floor?
    Brian Smith replied 18 years, 4 months ago 3 Members · 7 Replies
  • 7 Replies
  • Brian Jones
    May 21, 2008 at 12:08 am
    Floor object doesn’t have any ‘real’ geometry (points, ploys, edges and normals) so it can’t be used as a collider but you can place a plane where the floor is (just under the floor or use a compositing tag on the plane and uncheck “Seen by Camera”)
  • Brian Smith
    May 21, 2008 at 12:10 am
    I’m sorry, I should’ve been a bit more clear on that. I am using a plane as the floor, not the “floor object”. That crossed my mind, so I tried a cube just to be on the safe side, and it didn’t work either.
  • Brian Jones
    May 21, 2008 at 2:35 am
    Can’t guess without knowing how it’s set up. Can you post it?
  • Brian Smith
    May 21, 2008 at 4:30 pm
  • Brian Jones
    May 22, 2008 at 2:29 am
    ahh, the Bend and the Cloth both want to do calculations on the points. The results can be nasty. If you were unrolling the cloth horizontally you could turn off the bend once it’s unrolled and let the cloth take over (or turn cloth on at that point) and it would drop. But since you are unrolling vertically and the cloth is meant to hit the floor, you can’t turn off the bend and let the cloth take over because once you turn off the bend the cloth reverts to straight in a single frame and the cloth can’t deal with that.
    The only solution I see (someone else may know something better) is to use the bend to roll the cloth, do a Current State to Object to freeze that. Then scale inwards with a soft selection to get the cloth not touching itself in the roll, then apply cloth tags to that with Self Collision turned on and let the cloth engine unroll it. Like this but if you need to have the roll be smooth like if it was being done with a bend deformer it would need something different.
  • Randy Johnson
    May 22, 2008 at 9:37 am
    I played with it too and ended up at the same solution as brian.
    /randy
  • Brian Smith
    May 23, 2008 at 4:02 pm
    That will work! Thanks guys!! I appreciate your help!
