Activity Forums Maxon Cinema 4D having some issues with the bridge tool
  • having some issues with the bridge tool
    Posted by Samuel Sidney on January 25, 2013 at 8:19 pm
    Hi I;m Sam. I am currently having the issue of my bridge tool not closing. I am modeling the main part using polys and then i insert a disc that i want to bridge to. When I start bridging the points together one will connect but then not the other. It looks fine but if i move the point that i just bridged to the edges of the polys arent connected in some spots. Im tearing my hair out!!!
    Rasmus Gerner replied 13 years, 7 months ago 2 Members · 1 Reply
  • Rasmus Gerner
    January 30, 2013 at 8:36 am
    That’s a odd one.
    Try to even the normals then brige once more my or alternativly try to weld the point together. If you deselect Visible only on your Select tool then select each point and m+q to wield.
    kind regards Rasmus Gerner
