Activity Forums Adobe Media Encoder Having several errors and in need of support! PLEASE!
  • Having several errors and in need of support! PLEASE!
    Posted by Erik Hansen on July 23, 2017 at 3:17 pm
    Hey im trying to render my After effects composition in After effects and im having these errors. At first when i tried to render in After effects the program just crashed and now when im trying to render in AME im having this:
    – Source: C: \ Users \ wartb \ Desktop \ Random Project \ Lenny Intro \ AE_AME \ tmpAEtoAMEProject-LennyFace1.aep
     – Output file: C: \ Users \ wartb \ Desktop \ Random Project \ Lenny Intro \ LennyFace_1.mov
     – Preset used: Match source (Reorganize)
     – Video:
     – Sound:
     – Bit rate:
     – Coordination time: 00:00:00
    07/23/2017 12:21:27 AM: The coding failed
    The source file’s video feed is not compatible with this preset. Select another preset.
     – Coordination time: 01:46:33
    07/23/2017 02:03:28 PM: The coding failed
    An error was detected in the file structure of Lennyss.mov when importing. Reading and writing in the file metadata (XMP) has been disabled.
    Exportfel
    Error in movie compilation.
    Import_Errors
    The importer returned the wrong result.
    Writing with exporter: H.264
    Writes to file: \\? \ C: \ Users \ wartb \ Desktop \ Random Project \ Lenny Intro \ leeenny.mp4
    Writing file type: H264
    At time code: 00: 00: 17: 17 – 00: 00: 18: 04
    Read with importer: ImportWave
    Reading from file: C: \ Users \ wartb \ Desktop \ Random Project \ Lenny Intro \ Ragga Twins – Bad Man.WAV.wav
    Reading file type: WAVE
    Returns at displacement: 17,867 seconds
    Component: Import Import Type Import
    Selectors: 23
    Error code: -1
     – Coordination time: 00:00:30
    07/23/2017 02:14:48 PM: The coding failed
    Exportfel
    Error in accelerated rendering
    Could not produce the frame.
    Writes to file: \\? \ C: \ Users \ wartb \ Desktop \ Random Project \ Lenny Intro \ lll.mp4
    At time code: 00: 00: 00: 16
    Returns at displacement: 0.000 seconds
    Component: H.264 of the Exporter type
    Selectors: 9
    Error code: -1609629695
     – Coordination time: 02:19:10
    07/23/2017 04:40:24 PM: The coding failed
    Exportfel
    If the audio uses VBR encoding in two rounds, try using either CBR encoding or encoding in one game.
    Exportfel
    Failed to complete rendering.
    Writing with exporter: Windows Media
    Writes to file: \\? \ C: \ Users \ wartb \ Desktop \ Random Project \ Lenny Intro \ Yes.wmv
    Writing file type: WMV
    At time code: 00: 00: 03: 06 – 00: 00: 03: 21
    Component: Windows Media of Type Exporter
    Selectors: 9
    Error code: 6
    Erik Hansen replied 9 years, 1 month ago 2 Members · 2 Replies
  • Chris Wright
    July 24, 2017 at 4:57 pm
    i’m not an adobe engineer but the jist looks like it doesn’t like that particular format for import. try transcoding it to prores, cineform, or dnxhd then import the new file. if it’s variable framerate(which i’m unsure as you haven’t posted mediainfo) you can try handbrake to constant framerate transcode.
  • Erik Hansen
    July 24, 2017 at 7:32 pm
    Thank you for the quick response but do you think you maybe could explain a bit more specific what to do since im all new to the transcoding stuff you mentioned etc.
