Activity Forums Boris FX Particle Illusion having problems with emitters not showing?
  • having problems with emitters not showing?
    Posted by Alan Lorence on December 3, 2007 at 5:34 pm
    Is anybody having problems with some of the emitters in the recent libraries not showing? They don’t show in the preview window, and don’t show in the stage window?
    The only emitter that may not show anything is the “Partial Erase” emitter that was released in this month’s library. All other emitters should be visible.
    Some emitters that people can’t see are (there are others):
    emitters_07_09: “New Fireworks Burst 01 (mb?)”
    emitters_07_11: “SnowBlow 01 (mb)”
    If you can’t see these emitters, please email support at wondertouch.com ASAP!
    Thanks.
    Alan.
    http://www.wondertouch.com
    Alan Lorence replied 18 years, 9 months ago 1 Member · 1 Reply
  • Alan Lorence
    December 3, 2007 at 5:56 pm
    We’ve figured out this “emitters not doing anything” problem.
    For some reason, some super emitters don’t create free emitters (and therefore don’t create any particles) at different framerates (I usually design emitters at 30 fps).
    So if your project framerate is set to 24 fps (for example), those certain emitters won’t show. You have 2 solutions:
    1) Change your project framerate to something else that works (not a great solution)
    2) For emitters that don’t work at the framerate you want to use, just increase the topmost “life” value a little until you see particles. (Add the emitter to the stage, move ahead a few frames so there will be something to see, select the topmost “life” property in the hierarchy, then click and drag the data point in the graph window up a little until the particles show.)
    Hope this helps!
    Alan.
