Activity Forums VEGAS Pro Having problems with alpha channel – help please!
  • Having problems with alpha channel – help please!
    Posted by Rob Weidenfeld on July 30, 2005 at 10:22 pm
    SCENARIO: I have imported four stills (PNG) with alpha channels, onto four separate video tracks in Vegas 5. Basically, I created an elevator, and, using pan/crop, the elevator doors slide open, revealing a video clip on a track below.
    I would like to render the elevator sequence separately, so I can use it with different video clips, but when I render it out, apparently the alpha channels go bye-bye. I have tried UNCOMPRESSED AVI, as that seems to be the one that has a checkbox for rendering the alpha channel. But I have tried ALL the compositing modes, but none seem to work, as the video clips below never show through the “black” part.
    Am I doing something wrong in the rendering options, or is it impossible to have an alpha channel in an AVI file created from several PNG files? Do I need to use the ‘compositing parent/child’ options?
    Thanks for your help!
    Rob
    Gary Kleiner replied 21 years, 1 month ago 2 Members · 1 Reply
  • Gary Kleiner
    July 31, 2005 at 12:24 am
    Right-click on the rendered clip and under Properties > Media Change the alpha channel setting (most likely Premultiplied will work).
    Alternatley, you could save your composited elevator sequence as a project, then drop it in another project as a nested .veg file which will preserve the alpha channel effect.
    Gary
