Activity › Forums › Maxon Cinema 4D › Having problem with my helicopter model rotor
Posted by Eddie Cantle on December 14, 2012 at 3:35 pmI’m trying to animate my model but for some reason my rotate tool spins but the rotor doesn’t. how do I link em. I tried doing it with a simple sphere and it worked just fine but when I open my model back again and apply the same method, The object doesn’t spin but the tool does. any help would be much appreciated.
Eddie Cantle replied 13 years, 7 months ago 2 Members · 14 Replies -
Darby Edelen
December 14, 2012 at 11:43 pmDo you have axis modification enabled? It should be disabled for this.
Darby Edelen
Eddie Cantle
December 15, 2012 at 1:10 amThanks for responding, I am fairly new to this, where exactly can I disable it? 🙂
Darby Edelen
December 15, 2012 at 6:26 pm[Eddie Cantle] “Does that work on pc and mac? I’m on a pc :)”
If you haven’t changed your keyboard shortcuts and you have an L key, yes it should work 🙂
Otherwise look for the below symbol in your toolbars and disable it.
Darby Edelen
Eddie Cantle
December 22, 2012 at 2:08 amHi I managed to get my front rotor working but the rear is giving me a hard time. Please check out my video to see whats going on…..I really need someone to help me out 🙂
Darby Edelen
January 2, 2013 at 3:34 am[Eddie Cantle] “Hi I managed to get my front rotor working but the rear is giving me a hard time. Please check out my video to see whats going on…..I really need someone to help me out :)”
Freezing Transformations before keyframing your animation should solve this issue. Check the ‘Coord.’ tab of the object that is giving you trouble. Twirl down the ‘Freeze Transformation’ section and click ‘Freeze All’ (or ‘Freeze R’ as I believe that’s the only place you’re having an issue).
Darby Edelen
Eddie Cantle
January 9, 2013 at 2:39 amI recently purchased a hind helicopter model and I freezed all the coord
When I try to animate the rotor, it rotates but keeps coming out of the whole. it come out the whole rotating then goes back into it. what do I do?
Darby Edelen
January 9, 2013 at 9:50 amIs this the same as the previous problem? You’ll have to remove all keyframes on the rear rotor before you freeze the transformation, then re-do the animation.
Darby Edelen
Eddie Cantle
January 9, 2013 at 4:27 pm
