Activity Forums Avid Media Composer Having problem with grouping in MC 7.0.4
  • Having problem with grouping in MC 7.0.4
    Posted by Ken Calcaterra on September 3, 2014 at 8:35 pm
    I have both my clips set up correctly, synced in a timeline to check to make sure the sync is holding. When I group from a bin and then drag this into a timeline for multi-cam editing Avid is not lining the clips up with the mark ins. Has anyone else had this issue and how did you solve it?
    Desktop – Intel Core 2 Quad Q6600 @ 2.40ghz
    Ram – 6gb
    Nvidia Quadro FX 580
    Window 7 64 bit
    Laptop – Intel Core 2 Duo t9300 2.50ghz
    Ram – 4gb
    Nvidia 8700M
    Windows 7 64bit
    Peter Groom replied 12 years ago 2 Members · 1 Reply
  • Peter Groom
    September 5, 2014 at 1:31 pm
    HI
    I line up the clips on the timeline, mark in and out around the clip, go to the in point, match frame and then create a sub clip into a bin FOR EACH TRACK. Then i highlight these sub clips in the bin, create a subgroup and use this in the timeline on track 1.
    Works well for me. especially if you map some functions to the keyboard for fast operation.
    Peter
    Post Production Dubbing Mixer
