Activity Forums VEGAS Pro Having problem watching Pre Rendered Project??
  • Having problem watching Pre Rendered Project??
    Posted by Don Cobble on October 1, 2010 at 9:56 pm
    I have a relatively fast computer. But I am having a hard time viewing my project prior to rendering. Is there a upgrade or video card or something I can get to view unrendered files better??
    or how fast a computer do I need. Or can you use proxy files with Sony Vegas? or should I convert the format from 1920×1080 MP4?
    Open to anything????
    Don
    PC
    I7 2.8 Ghz 8GB Ram
    Vista 64bit OS
    Nvidia FX 580 Video Card
    3-4 TB HD
    Vegas Pro 9 32bit & Vegas Pro 9 64bit
    Camera
    Sony EX1 shoot in 1920×1080 30P
    John Rofrano replied 15 years, 11 months ago 3 Members · 5 Replies
  • John Rofrano
    October 2, 2010 at 2:11 am
    You can use Shift+B to perform a RAM preview of small looped sections of the timeline. There are some HD formats that no computer can keep up with and Vegas does not use the GPU for preview so a video card will be no help. Keep your preview settings low (on draft if you have to). make sure that your project settings match your source footage settings. This will give you the best preview. Also making the preview windows smaller will help.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Graham Bernard
    October 2, 2010 at 4:36 am
    John – would it be valuable, sensible to cut in converted, proxy files and then swap back at finish? Any value in doing this? – I’ve always wanted to ask this.
    Grazie
  • John Rofrano
    October 2, 2010 at 12:32 pm
    [Graham Bernard] “John – would it be valuable, sensible to cut in converted, proxy files and then swap back at finish? Any value in doing this? – I’ve always wanted to ask this.”
    Yes, and that’s what VASST GearShift does. It converts all of your HD footage to DV Widescreen proxies so that you can edit at full speed and then it allows you to swap the proxies out for the original HD media before you render.
    That might be a good option for this situation.
    ~jr
  • Don Cobble
    October 2, 2010 at 2:03 pm
    Sir John I will get gearshift, but I have Production assistant will that do the same thing?
    PC
    I7 2.8 Ghz 8GB Ram
    Vista 64bit OS
    3-4 TB HD
    Camera
  • John Rofrano
    October 3, 2010 at 2:10 pm
    Production Assistant doesn’t give you the ability to swap the proxies in and out. GearShift is specifically designed to do that. You could make the proxies with Production Assistant but you would have to swap them manually which could be a lot of work if you have a lot of clips.
    ~jr
