Activity › Forums › Adobe After Effects › having issues with 3d tracking
Posted by Liran Tabib on January 19, 2025 at 11:12 pmon long tracking the track markers disappear while the camera solve is updating
Nir Vanaskitz replied 1 year, 7 months ago 2 Members · 4 Replies -
Nir Vanaskitz
January 20, 2025 at 8:04 pmHi Liran,
It sounds like you’re encountering a common issue with 3D tracking in After Effects, especially with long tracking sequences. When the track markers disappear during the camera solve phase, it’s usually a UI rendering limitation rather than a problem with the actual tracking data.
Once the solve finishes, the markers should reappear. If they don’t, you can try scrubbing through the timeline to refresh the display or zooming in/out in the Composition panel. Also, make sure your system has enough resources to handle long tracking operations, as memory limitations can sometimes cause display issues.
Hope this helps clarify things!
Best,
Nir-Vana -
Nir Vanaskitz
January 25, 2025 at 2:46 pmIf you’re having trouble with 3D tracking in After Effects, try the following:
1. **Improve Footage Quality**: Ensure your footage has good contrast and distinct features for the tracker to latch onto. You can enhance this by adjusting brightness or adding a slight contrast boost.
2. **Use the 3D Camera Tracker Effect**: Apply the 3D Camera Tracker to your layer and let it analyze a longer segment of the footage for better tracking accuracy.
3. **Check Tracking Points**: After analysis, review the tracking points for stability and proper placement. Delete any unstable or irrelevant points that might be causing issues.
4. **Create a New Camera**: Once tracking is successful, generate a new camera from the tracker to match the scene’s motion accurately.
These steps should help resolve common 3D tracking issues in After Effects.
Best,
Nir-Vana
