Activity › Forums › Maxon Cinema 4D › Having Errors In Playing Audio In Cinema 4D
  • Having Errors In Playing Audio In Cinema 4D
    Posted by Marcel Flowerson on December 13, 2015 at 9:23 pm
    Hello, I have recently been trying to sync some audio with some smoke in cinema 4D, I have the espresso down now all Im having issues with is my audio playing and I was wondering what the criteria for audio formats is and I really need help with this.
    Thanks, Marcel
    Marcel Flowerson replied 10 years, 9 months ago 2 Members · 4 Replies
  • Brian Jones
    December 14, 2015 at 7:48 pm
    from the Help
    “Sound Formats
    The following native sample sizes (with arbitrary sampling rate) are supported for sound files:
    8, 16 and 24-bit
    WAV Import
    Only uncompressed WAV files are supported.
    Markers included in the WAV files are imported into CINEMA 4D.
    AIFF-Import
    Uncompressed Mac sound files are also supported.
    QuickTime
    Furthermore, all sound files with formats other than those listed above and available in QuickTime can be played back if QuickTime is installed, i.e., *.mp3 and *.aac files.
    Internally, these will be converted to 44.1kHz in 16-bit and saved within the Project file.”
  • Marcel Flowerson
    December 15, 2015 at 1:06 am
    thanks for the reply, I have tried to change the audio into a WAV file with Audacity I made sure that the settings were set to 16 bit but I still run into the same issue
  • Brian Jones
    December 15, 2015 at 3:55 am
    is the sound uncompressed? How are you trying to use it? Can you post a the sound (or a bit of it if it’s large).
  • Marcel Flowerson
    December 16, 2015 at 1:36 am
    Hello, thanks for the help but I recently tried again and it worked perfectly which is weird but shows how reliable Cinema 4D can be at times.
