Activity Forums Adobe Encore DVD Having Encore problems
  • Having Encore problems
    Posted by Rob Mclain on November 16, 2009 at 3:35 am
    I am having some issues with Encore 3.0 when authoring blu-rays’s that I cannot seem to figure out. Everything works as I want it to in the simulator, however I get very different results when disc is burned and in a player. I have tried 3 players and all have play disc the same way. Here are some of the problems I am having:
    -Highlight schemes are wrong. Displays the action color only.
    -End action takes user to the correct menu, but wrong button
    -No audio when playing timeline from chapter menu, but works fine on play all. Same asset.
    Again, simulator plays it perfect like I want it. The loss of audio is really strange seeing as how if I access the timeline from a chapter menu I get audio on some chapters, but then have none if access from other chapters. I have it authored to go back to the menu after each chapter point. The play all works fine. I get audio straight through.
    It says that no updates are available.
    Frank Wylie replied 16 years, 9 months ago 2 Members · 1 Reply
  • Frank Wylie
    November 16, 2009 at 10:31 pm
    Are you burning directly to the disc? If so, try burning to a .iso image and then burn this to the disc using a third party tool like Imgburn, if you are using a PC.
    You can save yourself test media by downloading and using (again, PC only) a virtual drive like VirtualClone Drive: https://www.slysoft.com/en/virtual-clonedrive.html
    burn the .iso and then mount it virtually to see if everything works out before you burn/waste any media.
    See if this helps.
    Frank
    Frank Wylie
    “The camera is a base instrument; you must do violence to it…” Orson Welles
